Which is the best tool to export .ico files from photoshop?
I used one tool long before, which created .ico files with 16 images for different res. Dont remember which one.
Can you suggest something?
Posted on 07-25-2007 at 04:05:17 PM
sosoe222
Posted on 07-25-2007 at 05:02:55 PM
Errr... I don't actually understand you. Do you ask for a tool to make .ico files? If so, my suggestion is ConvertIcon Online app which you can use without any additional downloads
Hope I was helpful
sk8erjonath
Vive le Québec Libre ! Profil: Penguin
Posted on 07-25-2007 at 08:16:35 PM
Well if you want to apply the .ico you've made on photoshop first you need to get Reshack and then find the ressources you want to change...must of icons are in shell32.dll ...
Thanks a lot, that works for me. However, I would prefer a plugin that fits-into photoshop and allows me to save .ico files right from photoshop. Thanks again.
