Windows Customization & Support : saab and 20 unknown users
Previous
Tutorial Request
n°2305
sosoe222
Posted on 07-11-2007 at 12:46:47 AM
http://www.crystalxp.net/galerie/en.id.520...-wallpapers.htm
Can someone explain me how to make that kind of effect?
n°2309
Posted on 07-12-2007 at 04:01:54 AM
That's very easy sosoe222 , just make curves with Pen Tool fill them with brush stroke of 1-2px and  merge all the layers , give layers Outer Glow .
That's it :jap:
PS :ar: Topic to be moved :whistle:
n°2310
sosoe222
Posted on 07-12-2007 at 11:32:28 AM
Can't make those curves well, damn it :frown: Can you post your outcome, please?
n°2311
OsquiGene
Posted on 07-12-2007 at 04:45:05 PM
To make the curves use this tool (red circle) and this adjustments for the glow (I dont know the english for "superposition" :err: but it's 8th of the list ):
http://www.crystalxp.net/forum/uploads/sm/monthly_07_2007/post-134086-1184251305_thumb.jpg
Sorry for my english  :beurk:
n°2312
Nagaya
Posted on 07-12-2007 at 04:47:55 PM
i think superposition is overlay.  :whistle:
n°2313
k_millio
Posted on 07-12-2007 at 05:40:32 PM
Actually, it's Screen :wink:
n°2314
Posted on 07-12-2007 at 06:37:25 PM
I came up with this:
http://img2.freeimagehosting.net/uploads/1776454c39.jpg
n°2315
OsquiGene
Posted on 07-12-2007 at 08:21:57 PM
Nice, but the lights on the background are maybe to straights :wink:.
n°2316
sosoe222
Posted on 07-12-2007 at 09:02:10 PM
Thanks, man! But I'm too stupid, I can't manage to make those curves :tongue: :winktongue: :cry:
n°2317
cellblade
Posted on 07-12-2007 at 11:14:27 PM
looks kinda easy... i`m going to try it...
edit: i either use a too thick or too thin brush... what size should i use for the brush?
n°2318
sosoe222
Posted on 07-13-2007 at 12:14:04 AM
Mmmm... brushes... good idea...
[EDIT] Still can't make it... what did you exactly do with that pen tool?
n°2319
Nagaya
Posted on 07-13-2007 at 01:11:17 AM
Thanks for the help k_millio :loveit:
ASHAR: good result.  :great:
n°2320
Posted on 07-13-2007 at 02:59:37 AM
A brush of 2px size would be suitable for the effect :wink: .
First make a curved path with the Pen Tool :ar: now Select Brush Tool and pick a hard circular brush of 2px radius :ar: set the foreground color to white :ar: create a new layer :ar: with the new layer selected , press A to pick the 'Direct Selection Tool' , right-click on the path and select 'Stroke Path' , select Brush from the list but do not enable the 'Simulate Pressure' option .
Good Luck :jap:
n°2321
cellblade
Posted on 07-13-2007 at 10:07:18 AM
i like to make high resolution pics... like 1280x1024 and 2px is kinda small for that...
i can`t get the outer glow to work either... it`s either to small or to big...
photoshop is a powerful utility ... but i still have much to learn...
edit: i came up with this... any advice?... `cause i don`t like it... :beurk:
http://i201.photobucket.com/albums/aa287/cellblade/lightningbolt.jpg
edit: sorry for the long post... but i made another version... i used a bigger brush and came up with this...
http://i201.photobucket.com/albums/aa287/cellblade/lightningbolt2.jpg
edit:last one i promise...
http://i201.photobucket.com/albums/aa287/cellblade/lightningbolt3.jpg
can anyone tell me wich one is the best and how to improve it?
n°2322
sosoe222
Posted on 07-13-2007 at 12:40:58 PM
Really cool, mate! :great: I will try out myself later!
I like all your wallpapers here! You're getting better & better! :great:
n°2323
Nagaya
Posted on 07-13-2007 at 12:49:03 PM
your results are good cellblade :loveit:
it is just a matter of how you draw your curves, and you can get very good results.  :great:
n°2324
pspgamer
Profil: Top Penguin
Posted on 07-13-2007 at 01:30:09 PM
Great results,
Ashar, What blend mode that you used in the outer glow?
n°2325
cellblade
Posted on 07-13-2007 at 02:13:51 PM
a bit of "off topic question"... why is it called lightning bolt... because lightning has straight lines...and hard angles...
this is more with curves... i call it some type of aurora... but it`s only my opinion... :neutral:
n°2326
OsquiGene
Posted on 07-13-2007 at 05:21:20 PM
For this wallpaper i'v used a 2px & 1px brushes :wink:
n°2327
Posted on 07-13-2007 at 07:21:42 PM
I have used 'Soft Light' and 'Overlay' as blending options for the Outer Glow , actually the glow of the curves is a complex fusion of different layers having different Blendiing modes :wink:
n°2328
sosoe222
Posted on 07-13-2007 at 10:30:55 PM
Background terrible is :tongue: ASHAR, what gradient you used for background? Anyway, comment the stripes only please:
http://i17.tinypic.com/61lea1e.jpg
It does look terrible in browser because it resizes the image, so I suggest you to save it and view it :wink:
n°2329
cellblade
Posted on 07-13-2007 at 10:47:24 PM
the stripes are good... i will post a screenshot with my blending settings of the glow because i guess that you need some help there also...
edit:
this worked for me...
http://i201.photobucket.com/albums/aa287/cellblade/style.jpg
if its not good enough... just play with the spread, range and size... until u get the effect you want...
n°2330
sosoe222
Posted on 07-13-2007 at 10:55:32 PM
That's what I actually done :tongue:
n°2331
sosoe222
Posted on 07-13-2007 at 11:12:05 PM
Here's improved version:
http://i17.tinypic.com/63r70aq.jpg
Sorry for the dimensions. I made it for my widescreen monitor. Thank you all for spending time here :meuh:
n°2332
sosoe222
Posted on 07-13-2007 at 11:41:16 PM
Here's a new one :meuh:
http://i19.tinypic.com/6fsdx6v.jpg
Previous
Top
