15 unknown users
[SOLVED] all the layer style changes at once..why?
n°2248
Nagaya
Posted on 07-05-2007 at 02:43:13 PM
hi guys...
i am in a fix...and i dont know how to solve this problem.
i will try to explain what is it..
1. i make a selection and put a shadow under the blend moded at 45 degrees
2. i make a second selection on a different layer and put the shadow at a different angle, lets say at 135 degrees
now when i do step 2 the shadow on the step 1 changes automatically in accordance with the one i specified in step 2.
it means the shadow in step one also becomes 135 degrees without me doing any changes
it is very strange. :neutral: ..anyone has any idea how to stop this...this is freaking me out!!
i am trying to have shadows at different angles on two different layers and it is not working..!! HELP!
n°2249
Posted on 07-05-2007 at 03:17:17 PM
- Go to the Layer Style of one of the layers.
- Go to the shadow tab.
- After the degree part, make sure 'Use global light' is not ticked.
Good luck. :wink:
n°2250
Nagaya
Posted on 07-05-2007 at 03:22:09 PM
Good luck. :wink:
you are ONE BIG GENIUS Gruzz pal!! :loveit:
I am so happy to solve this problem! :happy2:
n°2251
Posted on 07-05-2007 at 06:20:54 PM
It is very pleasing to hear that your problem is solved :happy2: , Good luck .
