15 unknown users
Next
Help Needed To Make Effect
n°2303
cellblade
Posted on 07-10-2007 at 08:09:00 PM
sosoe222 wrote :
Perhaps you should add outer glow with lowered opacity there :neutral:
download the psd file...
n°2304
sosoe222
Posted on 07-10-2007 at 10:36:02 PM
Dude! I can't open the PSD :non:
n°2306
Posted on 07-11-2007 at 03:25:56 AM
After getting the radial background , do this to make a better blending of vurves:
1. Merge all curves into a single layer and name this layer as Curves .
2. Set the Fill Opacity of this layer to 0%.
3. Go to the Blending Options of Curves layer and give it a 'Color Overlay' of White color whith it's Blending Mode set to Soft Light/Overlay .
4. Also give theCurves layer an 'Outrer Glow' of white color with its Blending Mode set to Soft Light/Overlay and Opacity to 50-75% .
That's it :jap:
n°2307
cellblade
Posted on 07-11-2007 at 10:39:36 AM
thanks... i will post the result... and if people like it... tutorial coming soon...
n°2308
sosoe222
Posted on 07-12-2007 at 12:34:07 AM
I hope it comes out well!
Next
Top
