| X-Dranka Profil: Big Penguin | Last message on previous page:
Thanks, do you think that i can make a tutorial if I ameliorate the effect ? | |
Nagaya Profil: Penguin Pro | X-Dranka your results are very good. i really like your choice of gradients. i will wait if you can make a tutorial and post for all of us here. thanks very much.
Thank you very much, i will make the tutorial when i ameliorate the effect again  | |
Asher Genius is not born , it is made.... Profil: Moderator | Twenty minutes of Photoshopping led me to this:
Draginol Profil: Penguin Pro | Looks nice, but I think if the background was blurred it could look even better. BTW, did you draw the aura's they look very nice  | |
Asher Genius is not born , it is made.... Profil: Moderator | Quote :
Thanks ,I will try to make it more blur and yes , I did create that Aurora effect by myself . | |
Nagaya Profil: Penguin Pro | Quote :
the effect is very good ASHAR.  | |
X-Dranka Profil: Big Penguin | Quote :
Real nice it's more "vista" than the effect i needed before bt real nice  | |
