I'll wait for someone to answer my question first.
Posted on 06-30-2007 at 06:24:59 PM
Ofcourse you can use them with CS3. Just extract the *.abr file into *:\Program Files\Adobe\Photoshop (whatever version you are using) \Presets\Brushes and it will work.
sosoe222
Posted on 06-30-2007 at 06:53:35 PM
YoooOoooOooOooOo It works like a dream Woooohooooooo!!!!
