| superandomness Profil: New Penguin | | |
Asher Genius is not born , it is made.... Profil: Moderator | Here is an alternative of making a curve without using the Pen Tool: Make a curve with Polygonal Lasso tool or something else similar to this image:
 Now select the white curve layer and go to 'Filter-->Noise-->Median' , type your desired value for the radius and Apply the effect , you will have a curve similar to this image:  Good luck
Nagaya Profil: Penguin Pro | ASHAR. You are the wonder guy and so much help to novices like me on this forum. This is such a neat trick to make smooth lines. thank for sharing with us.  | |
Thanks for such boosting comments , let's see what superandomness has to say about it . | |
sosoe222 Profil: Penguin Pro | | |
Asher Genius is not born , it is made.... Profil: Moderator | Thanks for the praise . | |
superandomness Profil: New Penguin | That's fabulous! Thank you!  So by applying the effect, will it make the selection curvy too? | |
Asher Genius is not born , it is made.... Profil: Moderator | superandomness wrote :
No , the effect is not applicable on a sheer selection . | |
cellblade Profil: Penguin | well if you make the selection and put it in a new layer? wouldn`t that work?:neutral: maybe it`s a late reply... but i`m just saying... | |
Asher Genius is not born , it is made.... Profil: Moderator | @cellblade You are right , the filter can be applied to the selection on the condition that a pre-filled layer is selected , but I don't think it will help in making smooth curves. Moreover , I suggest that superandomness asked whether the filtrate can be applied on an edged selection to make it smooth . | |
