20 unknown users
(Problem Resolved) How to enlarge a path in Photoshop
n°1967
Nagaya
Posted on 04-30-2007 at 03:32:29 AM
Hi, I could not find an answer in the search so I am posting it here.
I made a path in Photoshop. Now I want to make it bigger, How can I do it? CRTL + T and dragging the corners results in edgy corners. Any ideas how to make a  path bigger without getting edgy corners?
http://i170.photobucket.com/albums/u248/nagayanobu/edgycorners.jpg
n°1968
simon.maildude@gmail.com
Posted on 04-30-2007 at 03:50:21 AM
Ctrl-click on the layer of the object you want to make bigger. Then, go into the "paths" tab on the layers pallette, and click "make path from selection" (on the bottom of the window). Finally press Ctrl-T, make your path bigger, select "make selection from path" and fill your selection with a color. Hope this works!  :meuh:
n°1969
Nagaya
Posted on 04-30-2007 at 04:05:17 AM
Thanks Simon, I was doing something wrong with the enlargement part. The method you told me works perfect. Thanks again!
n°1970
Posted on 04-30-2007 at 04:13:25 AM
If your problem is solved, please change tittle to "[resolved]How to enlarge a path in Photoshop"  :he:
