13 unknown users
Visual Styles
n°1905
joeyastroboy
Posted on 03-22-2007 at 02:52:23 AM
hey
i dled the crystal clear xp bricopack and installed that worked fine but i wanted it to look diff so i uninstalled and the found the Vista XP visual style under the visual style catagory. but how do i then get my comp to look like that (with the side dock and all)
n°1907
Draginol
Posted on 03-22-2007 at 06:19:58 AM
If your simply looking for the 'sidebar' style application, it's called PodXP.  You can download it below :smile:
:ar: Download
n°1908
Neil
Posted on 03-22-2007 at 07:37:00 AM
Welcome to Crystal XP joeyastroboy :angel:
n°1926
joeyastroboy
Posted on 03-26-2007 at 03:53:46 AM
hey thanx guys, but yeah looked at podxp, not really wha i was goin for, like kinda want to redo the overall look of xp, so yeah how do i get the visual styles loaded with the dock bar and all
n°1928
Draginol
Posted on 03-26-2007 at 01:46:23 PM
If you installed the Brico Pack, it should already come with a dock.
If it didn't, you can download ObjectDock or RocketDock.  I prefer RocketDock :smile:
n°1929
Posted on 03-26-2007 at 03:06:02 PM
The RocketDock site. RocketDock is free, and it's great software.  :great:
