Windows Customization & Support : saab and 15 unknown users
Wallpaper effects?
n°1856
GmT-Curwen
Posted on 03-12-2007 at 06:38:49 PM
Hi, i recently found this forum n it really amazed me, your tuts rule!
I have a request...there's something i always wanted to do with photoshop n i n ever knew how...
Did u see, on the Wallpapers Gallery, the images that are shinny, with complicated twists and that kind of stuff? (like Ice Queen, Aeris, Ghost and Vista BAll 2 background). What i want is to learn how to do it with photoshop (or whatever they use to do that) without using brushes made by someone else...i would appreciate a lot if someone could help me.
Sorry if my english is not pretty good, im from Argentina =)
n°1857
Posted on 03-12-2007 at 06:45:01 PM
Hey and welcome to the forums! :smile: Although this is not the place to introduce yourself, we won't wine this time because you've got questions too. :wink: Shiny images are called Crystalized images here. You should use a white to transparent gradient for this. The Tux tutorials can give you an idea on how to use it. G1 Tux tutorial - G2 Tux tutorial - TinyTux tutorial.
Good luck! :smile:
Edit: your signature is too big!
n°1858
GmT-Curwen
Posted on 03-12-2007 at 07:09:21 PM
But how do they do that? they first do a line with no lights and shadows and crystalize some parts? How do the efect of the lines mixing or crossing?
Thx a lot anyway, it helped very much ^^
n°1859
Posted on 03-12-2007 at 07:30:00 PM
If you could give me a sample image, it would be easier to explain.
But for crystalize, they use Gradient Tool.
White to transparent -> Linear Gradient -> Put it somewhere on your object. :smile:
n°1860
-Shift-
Posted on 03-12-2007 at 07:59:42 PM
the white to transparent gradient is probably the best thing you can use :biggrin:
n°1868
GmT-Curwen
Posted on 03-13-2007 at 12:16:59 AM
Sorry for the trouble, i found a thread thats almos the same thing, heres what i wanted to do:
http://forum.crystalxp.net/index.php?showtopic=14216
Anyway i still ask, is there someway to do the photos 1 and 2 with ps?
n°1869
-Shift-
Posted on 03-13-2007 at 12:21:12 AM
its pretty hard
maybe a good expert
you sholud try Maxon Cinema 3D
n°1870
GmT-Curwen
Posted on 03-13-2007 at 12:24:17 AM
Thx ^^
n°1871
-Shift-
Posted on 03-13-2007 at 01:42:45 AM
Thx ^^
you can download a demo :biggrin: it is a really nice application :oui:
