| zetacu Profil: New Penguin | hi im relative new with photoshop and i try to follow the totorial to convert an image to crystal but i try and i can't finished because i don't imagine the folow steps, if someone can modify the image i will apreciate your help  | |
sosoe222 Profil: Penguin Pro | Here, let me try my new skills in crystalizing! EDIT: I can't figure out what do you really want, it's well crystalized except the ear, which I unfortunately can't do  | |
zetacu Profil: New Penguin | well i try to crystalize everyting but the horns, the ear and the mouth i just cant figure it out how can i crystalize it it. the face in general looks more or less ok but i thik it can be better the eyes are ok  | |
sosoe222 Profil: Penguin Pro | Take laso. But you must practice to be precise with it. Well...that's what I think at least you should do. | |
-Shift- Profil: Big Penguin | i have something let me know if you like it *.psd: here
 its not that good, quick draft  i can make it even better if you want Edit: most of the crystallization can be done with the pen tool (P), which i wanna learn to master , and the polygonal lasso tool (L), which is very similar to the pen tool, but you make selections, instead of creating the shape  | |
you should just mess around with the tools and the transformations heree in the forums, there is no "wrong way" all creations are good  | |
zetacu Profil: New Penguin | | |
Draginol Profil: Penguin Pro | Looks cool, nice job. The aliasing is so bad though  | |
-Shift- Profil: Big Penguin | the aliasing is pretty bad, try saving as .png or use a little inner glow
sosoe222 Profil: Penguin Pro | Try anti-aliasing or use blur  | |
-Shift- Profil: Big Penguin | | |
zetacu Profil: New Penguin | i think i made it i just add a black background and thats it i like it very much  i don't know why but the image on PS looks very good and the gif and the jpeg bmp looses some definishion can someone tellme why? | |
-Shift- Profil: Big Penguin | An image goes through a lot of transformations when going into other formats, but through .png, it doesn't lose so much quality that's what I think | |
zetacu Profil: New Penguin | your right i save it like png and doesn't loose much quality  | |
Very Good effort ZETCU. Keep up the good work.  | |
-Shift- Profil: Big Penguin | i will apply the shadow effects the original file has just bare with me | |
