| Reinaldo Profil: New Penguin | hi, i just wanna know how to do icons who's work in 32x32 and 48x48 without bad quality! someone knows? hope someone help me! | |
nono34 Profil: Penguin Pro | make your icon in 48*48 and lower your icon in 32*32  | |
Reinaldo Profil: New Penguin | | |
InteRNaZional Profil: Big Penguin | Quote :
J'ai pas compris aussi lol. To do your icons first make it in big size, (800*600) then make it to 32*32 or 48*48 | |
Reinaldo Profil: New Penguin | i'm not time now for do, but its really works? if a do a icon in 256x256 and resize to 32x32 he go work in any resolution between 32x32 - 256x256? its this? | |
Draginol Profil: Penguin Pro | Yes that's right. It also helps if you have IconWorkshop, it exports them in all sizes at once. | |
nono34 Profil: Penguin Pro | sorry i didn't understand your queston and my english is so bad... make your icon in 1024*1024 (not 800*600 itisn't proportionnal) and resize in 32*32 and 48*48  | |
sabchuphai Profil: Big Penguin | I try to make mine in 600*600 and then contract then to the desired size. The come out to be just fine.  As said by [Chromatix] try making icons in perfect square. | |
Reinaldo Profil: New Penguin | thanks guys, and Disko, where i found this IconWorkshop? | |
Gruzz Profil: Moderator | Well, you could try Google yourself. The IconWorkshop website can be found here.  | |
lefreut Profil: Big Penguin | You can use ToYcon if you want a free tool  | |
Gruzz Profil: Moderator | No point! Besides, some people on these forums are girls.  | |
Reinaldo Profil: New Penguin | what is "besides"? can you put in a more basic english? its aboult the "thanks guys" i go edit | |
Gruzz Profil: Moderator | Yes, it was about that. It's no problem!  | |
Reinaldo Profil: New Penguin | hehe, but now i'm curious, tell me, in other words, what its "besides", i don't know this word | |
Gruzz Profil: Moderator | Besides, means something like 'by the way' or 'did you thought of'.  | |
Reinaldo Profil: New Penguin | ok, i understand now! thanks | |
