Windows Customization & Support : saab and 21 unknown users
[RESOLVED]How to save in transparent mode?
n°1755
Reinaldo
Posted on 03-06-2007 at 11:15:35 PM
hey guys!
well, i do the b&b icons tutorial, but after i saved the icon 256x256 with the transparent background,
if i open the icon one more time, the background its white!
what i do?
n°1756
Spartakis
Posted on 03-06-2007 at 11:20:37 PM
In which format do you save your picture?
n°1757
Reinaldo
Posted on 03-06-2007 at 11:51:10 PM
jpeg,jpg
n°1758
sabchuphai
Posted on 03-07-2007 at 12:12:12 AM
You will have to save them in either the GIF or PNG format to get transparent background. :great:
n°1759
Spartakis
Posted on 03-07-2007 at 12:13:23 AM
Ok that's what I thought ... You can't save a transparent background with jpeg format. You must use PNG or GIF format when you save your icon.
n°1761
EldAnar
Xcoder
Posted on 03-07-2007 at 12:22:51 AM
PNG's better, if you save in GIF you will create aliasing :wink:
n°1762
Reinaldo
Posted on 03-07-2007 at 01:06:58 AM
thanks guys, i go test, and if works, i go rename the topic to resolved
thanks you all! this is the more fast forum i join!
