| sosoe222 Profil: Penguin Pro | OK, I am pracitcing how to make some crystalized images. I saw some of you pros making them, and I hell like 'em. I am trying to use some white to transparent gradient with lower opacity. But it always looks n00bish. So I would like to hear how do you make them. Teach me  | |
-Shift- Profil: Big Penguin | | |
sosoe222 Profil: Penguin Pro | Why couldn't you gimme the hyperlink Anywayz, thanks for pointing me  | |
sosoe222 Profil: Penguin Pro | OK, here's something I did in few seconds. Ain't anything special, since it's just a test. I tried to crystalize the head of the second dude. Bad, huh  | |
Draginol Profil: Penguin Pro | Take some time, your rushing it. | |
sosoe222 Profil: Penguin Pro | You're probably right. Crystal effect looks better on one-color graphics  | |
sosoe222 Profil: Penguin Pro | Is this a bit better  Nope  | |
Gruzz Profil: Moderator | Yes, but the size of the crystalization on the head doesn't make much sense to me! Make it a bit bigger. You shouldn't see the end of it on top of the head.. yea try to figer that sentence out first.  | |
sosoe222 Profil: Penguin Pro | The position and the size don't matter now. Just tell me what do you think  | |
Good try Sosoe222...! The size and the position does make a difference though..! See what I tried on the same image as yours..! 30 Seconds job..! You can get awesome results if you spend more time on this..!
Draginol Profil: Penguin Pro | Actually size is everything. When doing designs on an image, it's crucial that everything is right on the money. So size is huge! | |
sosoe222 Profil: Penguin Pro | Thanks, guys. Well, I'll keep this in mind. This is really helpful. I'll be coming again later to post something more if I could work out  | |
Glad to hear that you find this helpful. Keep posting your results.  | |
sosoe222 Profil: Penguin Pro | OK, I will. And of course that this is really helpful... | |
Gruzz Profil: Moderator | It's supposed to be.
sosoe222 Profil: Penguin Pro | | |
