General & Off Topic Discussion : jimmorgan and 19 unknown users
Photoshop Brushes?
n°1699
squidgy
Posted on 02-23-2007 at 10:27:41 AM
please forgive a newbie i may be posting in the wrong section.   i need a little help i have just recently started using photoshop, i needed grass brushes for a project i am about to start and found the ideal items in the gallery (thanks for putting them on) but as a newbie i have no idea as to how to install them in pshop. could you lovely people help me out ?     apologies again if i have posted in the wrong section :smile:
n°1700
Posted on 02-23-2007 at 10:33:35 AM
Welcome to the forums squidgy!  :party:
How to install brushes
Place the *.abr files into:
*:\Program Files\Adobe\Adobe Photoshop *\Presets\Brushes
Brushes created in Photoshop 7 or later will not work in earlier versions of Photoshop. Any Photoshop brushes should work in Photoshop 7 and later! But this is probably not a problem.  :smile:
From the Brushes Palette in Photoshop, click the small arrow in the upper right corner of the palette, and choose load brushes. The brushes will be added to the current brushes.
It's not hard, but if you've got any problems let us know!  :loveit:
n°1701
squidgy
Posted on 02-23-2007 at 10:37:28 AM
wow that was quick thank you so much for your help, if i do have problems i will indeed get back to you . again thank you for the speedy reply. ( that fast i did'nt have time to make a cuppa) :biggrin:
n°1702
Posted on 02-23-2007 at 10:46:18 AM
I try to be fast  :he: Now go and try and tell us if it worked. You can find a lot more brushes here!
n°1703
squidgy
Posted on 02-23-2007 at 10:49:33 AM
woohoo it worked thanks again gruzz and thank you for the link. one very happy photoshop and crystal xp user :mdr:
n°1704
Posted on 02-23-2007 at 10:52:44 AM
Nice to hear that it worked!  :great: You can stay part of this community if you want.  :jap:
n°1705
Draginol
Posted on 02-23-2007 at 11:05:22 AM
You can also find some nice brushes here by Chozo-MJ; one of our own members :wink:
