Windows Customization & Support : saab and 18 unknown users
Can someone create shell32-toolbars ?
n°1688
Breakfastclub
Posted on 02-20-2007 at 11:08:19 AM
Hi Graphic-Genius !
Can someone create/edit the ressources with the green vista-folder,
I mean change the brown folder against green folders ?
http://img359.imageshack.us/img359/8213/neu2wq2.th.png
http://img246.imageshack.us/img246/3216/neu1te1.th.png
When some1 wanna try it I upload the ressorces ...
n°1689
Draginol
Posted on 02-20-2007 at 11:11:26 AM
I'm happy to help if you can be a bit more clearer on what exactly you want to achieve :jap:
