| albertx75 Profil: New Penguin | Download the file, unzip it and drag and drop the file in the windows add-ons/themes on the left window you found it on the menu "tools" | |
Breakfastclub Profil: Penguin Pro | KTZ wrote :
Hello Evryone i'm new and i'm totally shocked how cool is this site and the things inside it
Welcome to CrystalXP, KTZ !  Thanks for your kind words, feel free to be a part of this community ... You drag and drop the skin (un-zipped, if it zipped) it into firefox - addons - themes  | |
KTZ Profil: New Penguin | Thx for helping me but i relized now that i want the trasparent windowed mode that he uses, not the firefox skin How can i use that nice looking style on my windows? I need to install something? | |
CustMax Profil: Penguin Pro | Hello You want the transparent windows ? If it is that you need WindowsBlind which is paying I believe that you did not post at the good place | |
Glass2Kwill make your windows transparent  | |
lillferraz Profil: New Penguin | Hi, Breakfastclub! This is the solution I was looking for. It actually works. Thanks! The other ways I found don't work on WindowsXP... Lill
Draginol Profil: Penguin Pro | Glad you worked it out  | |
