Windows Customization & Support : saab and 21 unknown users
Help needed for crystallizing
n°1483
sep
Posted on 01-10-2007 at 05:03:15 PM
Hi guys,
I saw a lot of newbies like me found great help here, so I thought I'd just ask for some myself :tongue:
I am currently trying to crystalize (add gloss to) the "tomtom" logo you can see below.
http://img78.imageshack.us/img78/8406/tomtomuu2.jpg
Here's what I've come up with so far:
http://img361.imageshack.us/img361/3673/tomtomlogocrystalgd4.png
I'm not too satisfied with the result, so I'd appreciate it very much if some of you Pros could help me!
For that you can work with the logo-image, I've attached a rasterizable .eps file, so you can have it in any resolution.
Thanks in advance for your help!
sep
n°1493
Posted on 01-12-2007 at 07:25:05 PM
Welcome to Crystal XP sep :angel:
If you have designed this logo in Photoshop then please provide us with the psd file so that we can edit it easily.
Have fun :party:
n°1494
sep
Posted on 01-12-2007 at 07:29:13 PM
Thanks for your reply ASHAR :smile:
The logo itself is in .eps format (openable and rasterizable in Photoshop) and attached to the first post.
I don't like the crystal logo I did myself so I deleted the .psd for the second one, you would have to use the original logo to start with.
Thanks again
greetings
n°1495
Posted on 01-12-2007 at 07:38:20 PM
When I open the .esp file (the one u attached in zip file) in Photoshop , it just shows me a flatten image just as if it is an image.
I want the .psd file with all the layers including the two hands.
I can design the logo by myself but it would be surely somewhat different from the original.
n°1496
sep
Posted on 01-12-2007 at 11:55:46 PM
OK here you go.
Greetings
sep
n°1497
Draginol
Posted on 01-13-2007 at 04:11:01 AM
Just something quick :jap:
Updated soon.
