| Damballa Profil: Penguin | [Sorry 4 my english] The thing is, how I can make:  Look the Heart ... Bottom part, I want to make it (Circular to the "BALL" it see too plane.. understand? PS: Make a phorum for "Graphic Help" I did not see no one.. EDIT: damn, now I see the Help request Forum ;D .. sorry | |
Draginol Profil: Penguin Pro | Hi and welcome here I don't quite understand your request... Are you trying to make the bottom part of the heart more rounded? | |
Damballa Profil: Penguin | I want make the heart "More rounded" to envolve the ball.. | |
Asher Genius is not born , it is made.... Profil: Moderator | Hi Damballa and Welcome to Crystal XP  To get your heart rounded along with the sphere ,first ,remove the black inner-shadow of heart ,it shows that the heart is pressed inside.Now increase the Range of outer glow to make it more blur and pervasive.Finall ,go to Filter->Distort->Spherize and give the heart layer a Vertical spherization of about 35% to 60%.Also add a glossy reflection on the heart layer. | |
Damballa Profil: Penguin | Quote :
Hi Half life khelien? and Welcome to Crystal XP  To get your heart rounded along with the sphere ,first ,remove the black inner-shadow of heart ,it shows that the heart is pressed inside.Now increase the Range of outer glow to make it more blur and pervasive.Finall ,go to Filter->Distort->Spherize and give the heart layer a Vertical spherization of about 35% to 60%.Also add a glossy reflection on the heart layer.
Thanks you alot, I'm gonna do this.. anything I come again.. PS: It don't is inner-shadow, its de bevel n emboss, but im gona fix it anyways.. what you mean with blur and pervasive? I speak spanish  EDIT: I continue playing with the heart, but spherize just deform it ;(, some way to spherize it with out loss the form of the heart? Before: After:
Asher Genius is not born , it is made.... Profil: Moderator | Damballa: Skip the spherization part ,it is not making the heart better in any way . Don't remove the uuter glow ,just increase its Range from blending Options to make it more blur and spreaded.It would be better if you provide the .psd file for making us free to transform it in our own way. | |
Asher Genius is not born , it is made.... Profil: Moderator | I modified it according to my taste and came up with this:  Hope you like it  | |
Damballa Profil: Penguin | Nice, you used 2 Heart layers? one on other? Post the PSD to check it ;D | |
Asher Genius is not born , it is made.... Profil: Moderator | You can download the PSD file from here. | |
Damballa Profil: Penguin | Thanks you alot.  Looking For a Proxy  Very Well! Questions: How do you put that cross.. ? How you make layer 4 and 5 :| | |
Didas le soleil se lève avant moi, je me couche après lu Profil: God of Penguins | | |
Damballa Profil: Penguin | Sorry, the normal forum rulz is 400x100.
Asher Genius is not born , it is made.... Profil: Moderator | Quote :
What do you mean by cross? Quote :
Here's how you can achieve a result similar to Layer 4 and Layer 5 : 1. Ctrl+Click on the Shape 1 layer to load its selection and go to Select->Modify->Contract and type 1(px) ,click OK button. 2. With the selection thus loaded ,create a new layer with name upper gloss and fill this layer with any color. 3. Without deselecing ,move the selection 30 to 40 pixels downward (Shift+Down Arrow key) and press Delete key to clear the selected area.Reduce the fill opacity of upper gloss layer to 0%. 4. Set white as the foreground color.Go to the blending options of upper gloss layer and set Gradient Overlay with these settings:
 For creatig Layer 5 ,repeat the same procedure and move the selection in upward direction while following Step 3. | |
Damballa Profil: Penguin | Thank you alot  I mean that cross in the middle what appear and disappear with Ctrl+H | |
I set rulers in the middle of the document which ca be viewd and disappeared by pressing Ctrl+: (and not Ctrl+H) . | |
reidoVell Profil: New Penguin | | |
victy23 A man is not old as long as he is seeking somethin Profil: New Penguin | Hello to you ---------------
To get Christmas Giveaway and Great Deals on Aviosoft Products Now
