13 unknown users
n°1284
plastiq
Posted on 12-01-2006 at 04:34:14 PM
Hi u all,
i'd like to know if i can use the .png files putting them directly on my desktop and adding a shurtcut to a program or to directory - like you can do with docklets in the objectdock (for example like the objectdock of vistapack)
..i mean...somthing like u can do with desktopx)
thank u all
(i'm a beginner o course..)
n°1285
Posted on 12-01-2006 at 05:11:08 PM
Hi plastiq and Welcome to Crystal Xp :party:
That's Avedesk , a perfect widget program for putting widgets as well as shortcuts of your directories and applications with a beautiful look on your desktop.
n°1286
plastiq
Posted on 12-01-2006 at 05:37:29 PM
thanks ashar!
i'llcheck it!
n°1288
plastiq
Posted on 12-01-2006 at 05:50:27 PM
i've already tried..but the application doesnt work..
it occupies 98% of my CPI but it doesnt really start..
dont know why..
n°1289
Posted on 12-01-2006 at 07:07:35 PM
It can't be.It is the lightest widget program I have ever seen.There might be problem in your Windows or your System.What are your system specificstions?
n°1290
plastiq
Posted on 12-01-2006 at 10:07:13 PM
xp sp2
P4 2.8, 1G ram
what could i check?
n°1291
Posted on 12-02-2006 at 03:15:29 AM
Ok tell me a thing ,Do you see a blue colored icon in systray whenever you run the Aveesk.exe file?
n°1294
plastiq
Posted on 12-02-2006 at 08:57:01 AM
nothing at all ashar..
when i launch avedesk i see my "occupied cpu" jump to 98-99% but the  program never become "ready to go" if u know what i mean..simply looks like it loops and i ìve to shutdown the application from the task manager..
i've also tried to shudown desjtopx before launch aveedsk thinking to conflict between the 2 programs but nothing chenged
thank for your interest and help..u really kind
n°1374
plastiq
Posted on 12-11-2006 at 09:00:35 PM
please guys...
does anybody knows another prg like avedesk that i could use to put my .png directly from desktop ?
dont know why, but avedesk doesnt start on my pc
thanks
n°1375
simncat
Profil: Top Penguin
Posted on 12-11-2006 at 09:04:13 PM
So, Podxp can do it too.
You can have a big icon with a png on your desk with podxp !!!
http://miaouchi21.free.fr/images/sims.JPG
n°1376
-Shift-
Posted on 12-11-2006 at 09:08:46 PM
thanx for taking my suggestion rocknb95!!!
its a really nica widget. maybe this will answer you question :smile:
n°1377
Draginol
Posted on 12-11-2006 at 09:09:07 PM
Yeh, PodXP is a great program, but it just can't acheive that effect of AveDesk. Mate I'll have a search for you, and see if I can help.
My AveDesk Desktop:
http://www.crystalxp.net/forum/uploads/sm/post-14373-1165867721_thumb.jpg
n°1378
-Shift-
Posted on 12-11-2006 at 09:12:02 PM
draginol:are you running on a mac jk
looks sweet :smile:
n°1379
simncat
Profil: Top Penguin
Posted on 12-11-2006 at 09:15:55 PM
I must maybe test avedesk.... :out:
n°1380
-Shift-
Posted on 12-11-2006 at 09:17:20 PM
ive tried both but i prefer avedesk :great:
n°1381
plastiq
Posted on 12-11-2006 at 09:58:35 PM
thanks rock..thanks guys..i'll ceck podxp
draginol..nice desktop!
n°1384
Posted on 12-12-2006 at 03:58:39 AM
plastiq I have my avedek working fine on my computer so I thought to share it with you.I have sent a PM to you along with the download link.Tell us whether it worked or not.
Draginol Nice and clean desktop.
n°1385
Draginol
Posted on 12-12-2006 at 06:16:52 AM
Thanks everyone...
And yes, I do love Macs... :mdr:
