| Kubix Profil: New Penguin | Lo folks i have went through your globe guide but seem to be missing something, might have something to do with being a total pillock with PS but i was wondering if someone could do a crystal effect on this wallpaper. http://www.kubix.pwp.blueyonder.co.uk/edWall.jpg I would really appreciate it as its for a theme and its the only bit i dont have done | |
Kubix Profil: New Penguin | 35 veiws and not one bit of help cheers folks | |
Asher Genius is not born , it is made.... Profil: Moderator | Welcome to Crystal XP kubix  A gloss effect would be fair enough to give your wallpaper a crystal look.I added a wave reflection on it and got this:
 For more crystal customization ,provide the .PSD file of your wallpaper. | |
Dannyayo Profil: New Penguin | that isnt a psd thats just the whole image | |
Asher Genius is not born , it is made.... Profil: Moderator | In which program have you created this wallpaper?If you have made it in Adobe Photoshop then give the .psd file which contains all the details of the wallpapers. | |
Kubix Profil: New Penguin | Sorry guys total noob here when it comes to photoshop my mate made it i will see if he has the psd file | |
Fazz Il jouait du piano debout... Profil: Penguin Pro | Ow ! You can be polite, no ?  | |
Kubix Profil: New Penguin | Hi Asher he made it in photshop but sent me a copy in Jpeg format and deleted the psd, is there anything you can do to make it more crystalised or a guide you can send me to do it. Many thanks on whats your've done so far | |
Asher Genius is not born , it is made.... Profil: Moderator | Kubix: Sorry for the late reply.I will try to make the wllpaper but there are many chances that it may not give you the exact result.The outcome can be better or worse. Hope you have not been depondent. | |
Draginol Profil: Penguin Pro | Hi Kubix, I'm trying to upload your wallpaper that I have made but I'm having some issues. It keeps saying that it's too large (it's not) so I'll try work it out and post as soon as I can. Thanks, EDIT: Ok, here it is. I have changed the text colour to black to show up the crystalization more. Enjoy!  | |
Gruzz Profil: Moderator | Nice result Draginol!  | |
grabennouitch Profil: Big Penguin | hi, just a test :
Asher Genius is not born , it is made.... Profil: Moderator | Nice one Draginol and Grabennouitch  | |
Draginol Profil: Penguin Pro | Gruzz + ASHAR Thanks for your feedback Waiting to hear from Kubix. | |
Kubix Profil: New Penguin | Thx for the work guys all look very nice and will come in handy. Again guys thx very much  | |
Draginol Profil: Penguin Pro | Glad we could help  | |
Damballa Profil: Penguin | Quote :
How you make that ~ "FORM" ? I just know make gloss effect with the circle tool the basic.. | |
Very easy. This tutorial should help you. | |
