Welcome to CrystalXP
To be better understood, your request must be more precise.
Are you using a bricopack or only a visual style?
If you're using longhorn Inspirat bricopack, go to "start menu/ All programs/bricopack/Longhorn inspirat/Objectdock/enable Objectdock.
If you're using the longhorn inspirat visual style, you can find Rocketdock on this page or Objectdock on this one
Topic to be moved
