| Awedacity Profil: New Penguin | I have a problem with CS2. When I try to open, it it always freezes the second time it "reads preferences" in the load up screen. I have tried reinstalling it, but still nothing. Please help.  | |
Awedacity Profil: New Penguin | | |
Gruzz Profil: Moderator | Hey Awedacity, I've only seen my Photoshop freezing when I started it up, and then went to look in another window. You've to make sure it's fully loaded before you do something else. | |
Awedacity Profil: New Penguin | I have tried that, but no luck. | |
Dannyayo Profil: New Penguin | How many brushes do you have and how many fonts because mine did that when i had too many fonts and brushes had to reinstall it aswell :'( | |
Damballa Profil: Penguin | Create a new Account in windows, and re-install it in the new session | |
Asher Genius is not born , it is made.... Profil: Moderator | Damballa wrote :
This topic is quite old and it does not need to be replied anymore ,however you can refer it. | |
Neil Chances are not had but gained....... Profil: Penguin Pro | Quote :
But If I'm not mistaken, though the topic is quite old, it's also quite hard to find the answer for the question Hint: Check your PC proformances, Make sure that your antivirus programm/s doesn't block the application  Quote :
I don't think that this is a problem with user accounts
Asher Genius is not born , it is made.... Profil: Moderator | Neil: It's very good to have you back in this community after a long break.Hoping to see you back in action again . | |
