| paokun Profil: New Penguin | hi, i'd like to know how to get the vista shell icons. for example the 'back' and 'forward' icons used in every window opened with vista..how can i get them? i wanted to make a skin for the browser i use, and i'd like to use those icons or the ones that are used in internet explorer 7. can anyone help me? | |
Asher Genius is not born , it is made.... Profil: Moderator | Welcome to Crystal Xp paokun  You can download Vista icons from here.I am not sure whether they contain all the icons you want.You can assist Photoshop for creating your own icons.You can also use ResHack to extract icons from shell32.dll file located in "SystemDrive/Windows/System32/" folder in case you have Vista installed on your PC. | |
paokun Profil: New Penguin | thank you very much! i'll check the icons with reshack tomorrow, i hope i can get them, thanks for the good reply!  | |
Slapp3r Profil: New Penguin | Cheers that will come in handy for me too. | |
iceman83 Profil: New Penguin | Hello I would like to insall new Media Centre Style on Windows XP Pro. Please tell me how I can do it. I have already downloaded this skin but now I have files .dll and don't know where I should put this file. | |
Asher Genius is not born , it is made.... Profil: Moderator | Hi iceman83, Use IconTweaker or IconChanger.Most of the Windows' default icons are stored in shell.dll and shell32.dll files.You can also search Windows Media Center's icons in .ico and .png types from web.In both softwares you have to change the icons manually.In IconTweaker ,you have to change it only once.After changing icons you can assemble them in .icontweaker theme file. | |
Crystalii Profil: New Penguin | Oi! I have a question too about these dll files, how do I put icons in the dll files?  | |
Asher Genius is not born , it is made.... Profil: Moderator | Hi Crystallizer and Welcome to Crystal Xp  Why do you want to get your icons on a .dll file?If you want to apply icons from a .dll file then simply use IconTweaker and if you want to pack them in a single file the use Winrar or Winzip. | |
