21 unknown users
help. tux install
n°1146
depro
Posted on 10-11-2006 at 12:08:14 AM
how do i install a tiny tux?
n°1147
marca
Posted on 10-11-2006 at 12:13:24 AM
What do you mean by install ?
n°1148
depro
Posted on 10-11-2006 at 12:21:56 AM
sorry. i'm completely newbee. what do i do with the tux from the "tux factory"?
n°1149
acdcrocks
Posted on 10-11-2006 at 01:58:50 AM
The files in the Tux Factory are plain image files, so there is no installation...
n°1150
marca
Posted on 10-11-2006 at 02:21:39 AM
You can take some tux and put in a dock like Rocketdock
n°1151
Posted on 10-11-2006 at 04:28:23 AM
Do you want to know how to save it on your computer?
n°1152
depro
Posted on 10-11-2006 at 10:43:56 PM
i know i can use them in rocketdock...but how? How can i insert them?
n°1153
acdcrocks
Posted on 10-11-2006 at 11:53:27 PM
This is very simple, simply right-click on the dockicon you want to change and the select Icon Preferences, or something like that. :oui:
Then a window will come up where you can change the icon, by browsing to the icon you want to replace the old one with... :oui:
If this was a little hard to understand, I don't blame you... :lol:
Hope this solves your problem.... :oui:
