Windows Customization & Support : s0cc3rstar6 and 35 unknown users
Need help
n°1126
comic_lover
Posted on 10-06-2006 at 03:41:15 PM
Hey guys!
Im new here and i need some help.
How would like to change the visual of my com... but how?
I downloaded this : http://img220.imageshack.us/img220/3297/previewzv3.th.jpg
But i dont know how to use it...
I wanna use that theme, but how?
Somebody help me please!
Cheers
ps: Sorry for the bad english... XD
n°1127
GuiTuX
Désherbant
Posted on 10-06-2006 at 04:34:29 PM
Welcome to Crystal XP :party:
If you want to apply a visual style on your comp, you'd better have a look on those two pages:
:ar: At first, you have to patch your UXtheme.dll file with UXtheme multi patcher. You can find it at the top of this page  http://forum.crystalxp.net/index.php?showtopic=55
:ar: Then, apply your new visual style as it's said on this page by Tessy http://forum.crystalxp.net/index.php?showt...amp;#entry97907
:wink:
n°1202
EldAnar
Xcoder
Posted on 10-27-2006 at 10:33:22 PM
Well, I think the best way to change your visual is to download the pack which is called Vista Bricopack. You can find it in the gallery. it's a window installer which enable you to change all your visual style, including the taskbar, most of the icons, moreover, it install a dock, ObjectDock, it change your Internet explorer skin and your explorer's skin, and also your screensaver.
With Vista Bricopack,all your computer looks like is the new Microsoft operating system.
