Windows Customization & Support : saab and 21 unknown users
Some software to make logons/themes for windows
n°1039
sgiraldoa
Posted on 09-19-2006 at 02:03:04 AM
Hi,
I'm really impatient to make some themes.
I want to create/edit windows logons, and themes/msstyles. I've been looking for good soft. I've tried "Stardot Logon Studio", it is impossible to export a .EXE file from it, it is a shame, you just can apply the logon if you have that software installed, I had the same experience using the stardot skins studio.
:frown:
Anyone knows a good theme/msstyle editor (also a logon editor), I would like to know which you (the professionals :great: ) use.
Bye!
n°1040
Xorios
Posted on 09-19-2006 at 09:45:29 AM
The topic is here.  :jap:
 :ar:   :lock:
