Windows Customization & Support : saab and 21 unknown users
How to get a high quality boot screen?
n°960
4tec84
Posted on 08-31-2006 at 06:01:47 AM
Is there some way to get or make the boot screen look better?
n°961
Draginol
Posted on 08-31-2006 at 09:21:22 AM
Hi and welcome here  :party:
I don't think it is possible to improve the boot screen image quality.  Every theme I have tried still has that pixillation about it, even the latest Vista Beta still looks like that :oui:
n°962
TPDK
Posted on 08-31-2006 at 09:30:33 AM
Not possible on Windows XP. The bootscreen has a restricted definition format : size to 640x480 pixels and only 16 colors.
:neutral:  :neutral:
n°969
Neil
Posted on 08-31-2006 at 07:39:23 PM
The bootskin appears before your VGA card is recognised by the system (ir before your VGA performance boots) So there isn't a way of getting a better look for a bootscreen :non:
You can try Boot Skin but it also uses 16 color bitmaps :frown:
n°980
lukeholmes
Posted on 09-02-2006 at 04:02:21 PM
I made my own Book Screen with a Visualization and it was pretty cool though... I know what you mean about the size... Its annoying...
n°1001
Neil
Posted on 09-03-2006 at 08:49:16 PM
lholmes, will it be usefull to share the way you did your bootskin here? :smile:
n°1175
karamveer_mudgle
Posted on 10-22-2006 at 12:04:24 PM
hey friend you can try on "ww.themexp.com" but you must register first to download bottscreens or other themes and you have to some software like stylexp or bottrandomizer or something like these because without these type of software changing your bootscreen is dangerous. bye enjoy xptheme.com
hey friend it is "www.xpthemes.com" sorry for above mistake bye
n°1176
Neil
Posted on 10-22-2006 at 07:45:26 PM
Welcome to CrystakXP kaykay :angel:
As I recall, xpthemes mainly has skins for 'Bootskin' :lol:
n°1183
Awedacity
Posted on 10-24-2006 at 03:31:13 AM
Why does it matter? It only shows up for a short period of time.
n°1186
Posted on 10-24-2006 at 03:09:43 PM
People like to change everything regarding their computer Awedacity. :wink:
n°1190
Awedacity
Posted on 10-24-2006 at 11:44:19 PM
Yeah, I guess so.  :sarcastique:
