19 unknown users
download
n°846
afroking3
Posted on 08-21-2006 at 11:02:11 PM
ok. i was wonderin you download these desaign right and and how do you but the on thing.like say you had a flash icon and they have F and you download something and it has the same f as flash how do you but the f you downloaded to the flash icon
i dont know if this is the right place
n°847
Neil
Posted on 08-21-2006 at 11:06:10 PM
afroking please make your message clear :oui:
n°849
Profil: Admin
Posted on 08-22-2006 at 12:18:39 AM
Please read the rules. Here, the size of your signature should not be more than 280x70 pixels
n°850
Draginol
Posted on 08-22-2006 at 08:27:04 AM
:oui: I'm finding it a little hard to understand too.  I got that you were talking about Flash, but what do you want to know about it?
Thanks afroking :wink:
n°851
d,st
Posted on 08-22-2006 at 04:23:52 PM
afroking this is the last warning make youre signature 280x70 pixels
n°853
k_millio
Posted on 08-22-2006 at 05:43:57 PM
Y$F, you're not a Moderator, so please don't talk about warnings ...
n°854
Neil
Posted on 08-22-2006 at 07:38:27 PM
Y$F, as I said to you before, you don't need to repeat what others had already said unless you have something to add more :bad:
and don't give such nasty warning which even admins of Crystal XP won't give :ouch:
n°856
afroking3
Posted on 08-23-2006 at 10:54:17 PM
i know some one just message me about the sig. anyway back to the thing. so you have flash right and the flash is a blue f right. i download a red flash sign that is a red f just like the flash sign. and i was wonderin how do i put the red f on the sign instead of a blue
n°859
Neil
Posted on 08-24-2006 at 12:11:35 AM
Still a little confusing in your explnation :ouch:
So you want a red 'f' for your signature? is that what you're saying?
n°860
Posted on 08-24-2006 at 08:11:05 AM
I think you want to change your icon?
To change a icon:
1. Right click the icon, choose the last tab, then change icon.
2. Click browse, click the icon you want, and choose ok.
Good luck. (I don't use English windows.)
n°880
afroking3
Posted on 08-26-2006 at 04:13:37 AM
i dont see that let me say what i see. i go to the last tab and i see advanced surch. and thats about it
n°886
Draginol
Posted on 08-26-2006 at 11:44:51 AM
afroking, is that what you want to do, change an icon?  If so then I can help you but right now I'm not certain what you want to do :ouch:
To change an icon say in the pinned section on your start menu do this:
1. Click start
2. Selct a program on your list, e.g Photoshop
3. Right-Click the program and select properties
4. When the menu opens select the tab 'shortcut'.
5. Once your in the shortcut tab select 'Change Icon'.
6. Locate the icon you wish to change too.
Hope this helps :oui:
n°950
afroking3
Posted on 08-30-2006 at 05:07:05 AM
i get to the tab part. do i hit tab on the keybord. or do i look for tab on the thing. i dont see tab anywhere
n°966
Posted on 08-31-2006 at 03:54:26 PM
Tabs.JPG Those, are called tabs.  :oui:
n°968
Neil
Posted on 08-31-2006 at 07:33:29 PM
And when we refer to the one in the keyboard, we'll say 'Tab Button' :smile:
n°975
Draginol
Posted on 09-02-2006 at 10:58:09 AM
So can you continue on with the steps of my procedure now that you know what 'tabs' are?
If not, feel free to post below :oui:
n°976
lukeholmes
Posted on 09-02-2006 at 03:36:13 PM
hehe... I love the way Firefox has tabs and IE doesn't... anyway... back to the subject...
n°986
Posted on 09-02-2006 at 04:50:12 PM
The new IE (Internet Explorer) comes with tabbed browsing. Besides, you can find more information about IE7 by clicking here.
n°988
lukeholmes
Posted on 09-02-2006 at 08:02:35 PM
Yeah-- I've read about it before... They bought some copyrights... From Netscape and FF ... But IE7 is still Beta
n°990
Neil
Posted on 09-02-2006 at 08:08:15 PM
Back to the topic please :smile:
n°996
lukeholmes
Posted on 09-03-2006 at 12:56:44 PM
Sorry-- its so easy to get distracted...
