14 unknown users
Next
Icon
n°967
Neil
Posted on 08-31-2006 at 07:07:12 PM
Draginol wrote :
I was just reading the link in your post, many people are saying that the application doesn't work for them.  Just tried for me and it doesn't work :ouch:
That's odd.
:oh: :fouet: wired !!
When you download it, you just have to open the application and then you only have to drag an icon to be converted in to Png or a png to be converted in to an icon :wink:
before you do this, just right click on the box for the icons and make sure you've selected at least one dimention from the menu :oui:
Update:* :ar: I've just checked with a fresh download from that above link, what can I say, It works :smile:
n°971
Draginol
Posted on 09-01-2006 at 10:21:56 AM
Ah ok, I'll give it another go soon, better get back to the topic though now :oui:
n°978
lukeholmes
Posted on 09-02-2006 at 03:46:45 PM
oh well... I have the got the registered Axialis... btw (off subject) are the other Axialis programs worth buying?
Next
Top
