Windows Customization & Support : saab and 20 unknown users
Previous
Icon
n°811
vajlent
Posted on 08-18-2006 at 05:23:11 PM
Wonder if someone could help me make an icon of this picture?
http://img503.imageshack.us/img503/1330/logold8.png
Or how to do an icon in photoshop CS2.
Thanx for a great site mates  :great:
n°812
TPDK
Posted on 08-18-2006 at 05:32:34 PM
n°813
vajlent
Posted on 08-18-2006 at 05:36:34 PM
And now?
n°814
TPDK
Posted on 08-18-2006 at 05:39:19 PM
and now you can use this icon, I just simply cropping your picture.
But if you want to make it yourself, you can see the tutorials for photoshop or Gimp on the website.
n°815
vajlent
Posted on 08-18-2006 at 06:20:11 PM
And how do i convert the png into a desktop icon?
Cant find a tutorial about that.
n°816
k_millio
Posted on 08-18-2006 at 06:31:20 PM
Try this :wink:
n°817
vajlent
Posted on 08-18-2006 at 07:23:15 PM
I dont understand a thing?
n°818
TPDK
Posted on 08-18-2006 at 07:24:49 PM
use the website that K-millio has mention, to convert your .png file into .ico file, necessary to change your shortcuts on your desktop.
n°819
Neil
Posted on 08-18-2006 at 07:28:44 PM
All you have to do is give the path of your png file in that online conveter and hit 'Convert' :oui: then you'll get the Ico file :wink:
Or you can download AveIcon Converter2 and convert your png files in to icons (you just have to drag & drop thm :smile: )
n°822
Posted on 08-18-2006 at 08:47:36 PM
logold8.ico
Here you are, I did this using the ConvertIcon site. Welcome to CrystalXP!  :wink:
n°823
vajlent
Posted on 08-18-2006 at 09:45:25 PM
Thanx, but there is no picture or logo at this link!!??
Gruzz wrote :
logold8.ico
Thanx, but there is no picture or icon at this link!!??
n°824
Neil
Posted on 08-18-2006 at 10:06:12 PM
You must download AveIcon :wink:
When you download, and open the application, It'll look like this
http://img158.imageshack.us/img158/51/1bx9.png
Then all you have to do is drag your .png file in to the right box and your icon will be generated automatically :oui:
n°825
TPDK
Posted on 08-18-2006 at 10:06:13 PM
you cannot see this link as a picture, you have to save the file !
and please, search on the forum about png/ico conversion and how to use icon file, there are lots of english topics about this subject.
n°889
lukeholmes
Posted on 08-26-2006 at 02:09:41 PM
One question though...
I have GIMP and Photoshop but can CS2 save .ico files?
I know GIMP can but I have tried with CS2 and failed...
n°898
Posted on 08-26-2006 at 05:13:54 PM
This is not possible within Photoshop, except if you download an plugin like this one.  :great: Good luck!
n°903
Neil
Posted on 08-26-2006 at 07:50:55 PM
And also you can use a program (gadjet) like AvIcon converter to convert the designs you've made as pngs using Photoshop or Gimp in to icons :wink:
n°914
lukeholmes
Posted on 08-28-2006 at 07:06:58 AM
Gruzz, thanks a ton bro! :wink:
That plug-in rocks!
n°915
lukeholmes
Posted on 08-28-2006 at 08:01:56 AM
Hey Guys,
The plug-in Gruzz gave me the link for works great! But I found a better solution... I have Axialis (Corporate) and I simply installed the Photoshop Plug-in for it and then transfer it to Axialis and then you get to save it in many sizes, etc...
Much better! :wink:
n°918
Draginol
Posted on 08-28-2006 at 12:49:33 PM
Hey Guys,
Much better! :wink:
Yes, Axialis IconWorkshop is a sweet program and that feature you skimmed on 'exporting' is just one of the great things you can do.  If anyone is interested in downloading a trial version, click here :oui:
n°924
lukeholmes
Posted on 08-28-2006 at 08:00:51 PM
Yeah, Axialis is a great program... I think its the best for Icons...
n°928
Neil
Posted on 08-28-2006 at 08:43:53 PM
Well, you also can use AvIcon to get icons files from 16x16 up to 128x128 :wink:
But Axialis is a great software :great:
n°945
lukeholmes
Posted on 08-29-2006 at 07:44:01 PM
Is AvIcon freeware?
Cause Axialis costs.... *grrr* lol
n°946
Neil
Posted on 08-29-2006 at 08:09:29 PM
Is AvIcon freeware?
Yes ofcourse :rofl:
AveIcon Converter2
n°964
Draginol
Posted on 08-31-2006 at 10:33:33 AM
I was just reading the link in your post, many people are saying that the application doesn't work for them.  Just tried for me and it doesn't work :ouch:
That's odd.
n°967
Neil
Posted on 08-31-2006 at 07:07:12 PM
That's odd.
:oh: :fouet: wired !!
When you download it, you just have to open the application and then you only have to drag an icon to be converted in to Png or a png to be converted in to an icon :wink:
before you do this, just right click on the box for the icons and make sure you've selected at least one dimention from the menu :oui:
Update:* :ar: I've just checked with a fresh download from that above link, what can I say, It works :smile:
Previous
Top
