Hi vajlent and Welcome to Crystal XP
please read the Forum Rules (check My sig) next time before you post a question
If you're asking to get borders in to your windows, you must use WindowBlinds skins compatible with Windowblind 5.0 or higher (shareware) because the window Visual styles doesn't give you that look
or you can use Glass2K to make your windows transparent
