19 unknown users
[Help]Rounded edges
n°476
TAFO
Posted on 07-07-2006 at 05:25:07 AM
Please i want to know how 2 make rounded edges in a photo by photoshop CS2; as if i'm cropping the image with the rounded tool, thnx in advance :smile: :smile:
n°478
vIcO
Posted on 07-07-2006 at 11:07:39 AM
Hi!  :meuh:
What is a rounded edge?  :oh:
Please read de rules : your sig is too big  :jap:
n°485
TAFO
Posted on 07-08-2006 at 03:44:22 PM
i said it man, as if i'm cropping with the rounded tool
n°486
Neil
Posted on 07-08-2006 at 08:19:47 PM
Well, I don't think that there is a way to do that with 'Crop tool' but I can tell you how to achieve such with 'Marque tool'
First open your image and make sure the image layer is turned in to 'Layer O' if not, double click on the 'Background' in the layer window and select OK from the pop-up window.
Then use 'Marque tool' to select the area that you wish to remain inside the rounded edge image. :wink:
http://img437.imageshack.us/img437/6807/13vd1.png
Then, go to Select>Modify>smooth and enter 5 as pixel number (this number can be vary depending on the radious of the rounded edge you wish to have)
Then your selection will turn-out like this, (notice that the edges of the selection are rounded)
http://img469.imageshack.us/img469/5929/22zx.png
Then Press Ctrl+Shift+I to invert the selection,
and hit delete
Now, your canvas will be like this,
http://img75.imageshack.us/img75/4011/37nw.png
Then use 'Crop tool' to cut out the unnecessary area
http://img81.imageshack.us/img81/7412/49pr.png
Finally, save the image as .png format (neither .bmp nor .Jpeg image formats supports transparency. so if you save the file in one of them, the empty area of the edge will be replaced with White :wink: )
So after you save the modified image as a .png format you'll achieve this :loveit: (an image with rounded edges.) :yipi:
http://img204.imageshack.us/img204/5238/53bx.png
Note:* There are many other ways in getting a rounded shaped edges for an image in Photoshop, but My idea is not to tell them all, but to help you to get a rounded edge for your image.
Remember:*
Saving the image as a .png format is the most impostant thing :rules:
Need more help?? :xeyes: send us a reply :wink:
n°500
TAFO
Posted on 07-10-2006 at 04:54:27 PM
thnx...but i failed 2 do it...i followed every step...however, i don't understand what's the purpose of the crop tool as it supports only hard edges :frown:
n°501
sexbox
Posted on 07-10-2006 at 08:05:07 PM
Okay, ill try.
First, press this button:
http://i54.photobucket.com/albums/g115/sexbox-designs/Help/1.png
Then, go to you're picture/signature/whatever.
Make sure the radius is 7 px.
Make a shape that you want, like this:
http://i54.photobucket.com/albums/g115/sexbox-designs/Help/2.png
Right Click, Save Selection As, and make it look like this:
http://i54.photobucket.com/albums/g115/sexbox-designs/Help/3.png
Now, you have the selection, do not leave the selection. Invert it, by pressing "Select->Inverse" or by pressing "Shift+Ctrl+I"
Now, just delete it from original. This is my outcome:
http://i54.photobucket.com/albums/g115/sexbox-designs/Help/4.png
You must save as .PNG. :loveit:
n°502
Neil
Posted on 07-11-2006 at 10:42:20 AM
Nice Tutorial Nan0me, :great: that's why I said that there are many ways to achieve this :wink:
And about the crop tool, It's designed to cut away unnecessary things in your image as rectangular parts. so It won't do all what you want :wink:
n°503
sexbox
Posted on 07-11-2006 at 11:10:58 AM
Thx Neil.
Looking forward, my wish = be a top penguin. :loveit:
n°507
TAFO
Posted on 07-11-2006 at 03:49:45 PM
thnx all...quite helpful :smile:
n°508
sexbox
Posted on 07-11-2006 at 04:35:26 PM
No problem, pal. Come again if you got more problems.  :loveit:
-Nano
n°510
Neil
Posted on 07-11-2006 at 08:40:49 PM
Good luck :great:
and keep up the commitment, It'll lead you towards it (personal experiance :mdr: )
