cnjsnjdj and 25 unknown users
Can someone teach me
n°11549
xanderneko
Posted on 06-05-2009 at 07:58:40 AM
Im having trouble after saving my animated .gif....
here's a example of my work
http://i206.photobucket.com/albums/bb282/delocroix66/TRY.gif
when you put on a black background you will see the white excess
http://s206.photobucket.com/albums [...] SILVER.gif
can someone give me a guide
Message quoted 1 times
Message edited by xanderneko on 06-05-2009 at 12:25:14 PM
n°11550
uttaresh
The Penguin Master
Posted on 06-05-2009 at 10:05:59 AM
It might be more helpful if you showed us the PSD.
One forum at a time.
n°11551
xanderneko
Posted on 06-05-2009 at 10:06:41 AM
PSD? how can i show you the PSD?
n°11552
uttaresh
The Penguin Master
Posted on 06-05-2009 at 11:15:17 AM
Upload it to http://www.uploadpsd.com/ and give us the link. ;)
PS: Oh, I get it now ... you didn't make it in Photoshop, is that what you mean?
EDIT: Here you go:
http://uploadpsd.com/file/64733.gif
If you were talking about something else, you should mark the problem and show it to us.
Message edited by uttaresh on 06-05-2009 at 11:30:13 AM
n°11553
xanderneko
Posted on 06-05-2009 at 11:26:57 AM
no i made it at photoshop.... but the problem is there is a small white portion arount my sig... i dont know how to remove it... my friend told me it is a noise...
edit
nope i still have the same result
if you put that sig behind a black background... you will see those white side
Message edited by xanderneko on 06-05-2009 at 11:43:04 AM
n°11554
uttaresh
The Penguin Master
Posted on 06-05-2009 at 12:06:31 PM
Ummm ... could you put it behind a black background, and then point out what you're talking about?
Are you alluding to the the inner glow on the holes? Is that not supposed to be there?
n°11555
xanderneko
Posted on 06-05-2009 at 12:23:23 PM
if you click this site it will direct you to my collection of animated sig... they are on a black background   :ohill:
and yeh those white glow shouldnt be there to.. it is just a simple circle nothing more
ok at the last frame i put a black background on it.... all the white edge should not be there
http://i206.photobucket.com/albums/bb282/delocroix66/33.gif
Message edited by xanderneko on 06-05-2009 at 01:49:48 PM
n°11556
meisterfdark
3.141592654...
Posted on 06-05-2009 at 08:06:54 PM
i think in gif you cant use transparency like jpg theres no way to use transpaency too.
but i dont know maybe you can do something with the alpha channel.!?
n°11557
uttaresh
The Penguin Master
Posted on 06-06-2009 at 12:30:36 AM
Ummm ... you can use transparency in GIFs. Try using another diffuse or whatever method. Maybe that'll take away the noise.
n°11558
xanderneko
Posted on 06-06-2009 at 07:38:09 AM
ok thanks.. a bunch gonna try it... sorry for the late reply
but on what way i could change the method...? sorry dont know any other way
Message edited by xanderneko on 06-06-2009 at 07:39:09 AM
n°11559
uttaresh
The Penguin Master
Posted on 06-06-2009 at 08:59:52 AM
Sorry, I really don't know what more you can do. We don't use GIFs on this site much. Mostly in static PNG format, or maybe JPEG. GIFs are of poor quality; so most of us opt for more complicated, but also better-looking Flash SWFs.
