44 unknown users
Changing RocketDock icons
n°11162
asianface94
Posted on 02-14-2009 at 08:48:17 PM
Hi everyone! RocketDock is amazing for me except whenever I try to change the icons to this http://hellokittyworld.tripod.com/downloads/miscs.htm
icons.zip.
It doesn't do that icon. It just shows the icon that says it no longer exists?
Thank you for answering!
http://www.crystalxp.net/forum/mesimages/316730/windows.JPG1..jpg
n°11163
Posted on 02-14-2009 at 09:18:58 PM
They are probably .ico icons. :yes: To use them on your dock you will need .png icons. :) You can use an (online) .ico to .png converter if you want to.
n°11164
asianface94
Posted on 02-14-2009 at 09:22:53 PM
THANK YOU so much!  :biggrin:
I'll look for a good converter!
n°11165
asianface94
Posted on 02-14-2009 at 09:27:53 PM
QUICK UPDATE: converticon.com was fast and painless.
Thank you again Gruzz!
