25 unknown users
About Resizing Images.
n°11122
gocool
Posted on 01-25-2009 at 09:50:53 AM
hi,is there any software which can resize a png file of particular size into different sizes at a time?For eg: if i want to resize a png file of size 40x40 into these sizes 18x18,64x64,128x128.Thnx in advance. :smile:
n°11123
x3lumin8x
Posted on 01-25-2009 at 01:50:03 PM
Up-sizing PNGs will make them look pixelized (distorted).
n°11124
y1n14i11
Posted on 01-25-2009 at 05:38:12 PM
i think so
and i only can say what neil say
Try to do a new one with those dimensions ;)
Bad English because German^^
http://www.abload.de/img/ballpsigvdfv.png
n°11125
Posted on 01-26-2009 at 03:56:02 PM
the icons are surely going to lose their quality if you resize them however , the icon still looks good if you decrease it's size to some extent but it gets pixelated if you increase it's size even by 10% , so if you want to increase the size , I would recommend you to remake the icon ;)
Igloo <---> DeviantArt
n°11134
codenamem2k
Posted on 01-29-2009 at 05:33:19 PM
Use Photoshop for png-png resizing... Use the save for web feature...
Use Axialis Iconworkshop for png-ico conversions...
