24 unknown users
Just a simple question?
n°11199
xCeres
Posted on 03-02-2009 at 11:14:12 AM
How do I remove the yellow background of this picture ?
I have Adobe Photoshop 2, and I don't know how  :he:
http://i43.tinypic.com/2e3wd50.png
EDIT:Ok here's the bigger one
Message edited by xCeres on 03-02-2009 at 12:24:06 PM
n°11200
uttaresh
The Penguin Master
Posted on 03-02-2009 at 12:14:52 PM
Wow, that's tiny. For a larger image, the procedure is simple. Use a combination of the eraser, magic wand, and lasso tools. Don't know what you can do here ... probably use the eraser to remove each pixel separately. Shouldn't take too much time, considering it's only a few pixels in area.
One forum at a time.
n°11204
xCeres
Posted on 03-03-2009 at 09:52:20 AM
Pretty please? ^^
n°11205
uttaresh
The Penguin Master
Posted on 03-03-2009 at 11:15:02 AM
I told you, that's how you do it. No other way. Here, I used the eraser for this one. Took me 5 minutes:
http://img26.imageshack.us/img26/4408/catrlf.png
n°11206
xCeres
Posted on 03-03-2009 at 11:32:17 AM
Another question xP
When I used that picture, why did it have a white background ?
I wanna know how to make the background transparent not white ._.
BTW:thanks uttaresh, I now know how to make the background disappear ^^
n°11207
uttaresh
The Penguin Master
Posted on 03-03-2009 at 11:51:38 AM
To have a white background, you can only store your image in GIF and PNG format. JPEG does not support transparency. PNG has far superior quality, but GIFs can store animations (moving pictures).
Of course, you must first enable transparent backgrounds. To do this in Photoshop, click on File>>New. For background contents, select Transparent.
Hope this helps. :)
n°11208
xCeres
Posted on 03-03-2009 at 11:59:31 AM
Does the transparent background also apply in bitmap formats ?
n°11209
uttaresh
The Penguin Master
Posted on 03-03-2009 at 01:35:14 PM
Not normally, no.
n°11213
xCeres
Posted on 03-04-2009 at 09:35:16 AM
But why do I see lots of pictures in bitmap format that are transparent?
I really wanna know how  :yes:
Message edited by xCeres on 03-04-2009 at 09:37:12 AM
n°11214
Posted on 03-04-2009 at 09:51:01 AM
To make a transparent bitmap you must make sure that the bitmap has been converted to Indexed 256 colour. 24bit Bitmaps will not make a transparent image. Make sure that pixel (0,0) in the top left most part of the picture has the colour you want to be transparent.
If you have a background colour that you do not want to be transparent put another colour at pixel (0,0), preferably 1 that doesn't appear in the rest of the image. Some image editors allow you to add a colour to the palette if needed.
In some cases setting colour 0 in the colour index also can help.
But, probably .png is much easier. ;)
n°11215
xCeres
Posted on 03-04-2009 at 10:48:33 AM
So can I do this using Photoshop 2?
n°11216
uttaresh
The Penguin Master
Posted on 03-04-2009 at 10:56:18 AM
But why would you want to?
n°11217
xCeres
Posted on 03-04-2009 at 11:22:43 AM
Oh just making logo's xP
And if you wanna know..
I need the picture in bitmap format and 24x24 in size.
And I want mine to be cool so I wanna learn how to make it transparent c:
So can I use my Photoshop 2?
Message edited by xCeres on 03-04-2009 at 11:25:21 AM
n°11218
Posted on 03-04-2009 at 05:35:14 PM
yes you can ;)
Igloo <---> DeviantArt
n°11225
xCeres
Posted on 03-05-2009 at 09:54:54 AM
guys why won't photoshop allow me to make the background transparent when in bitmap format?
n°11226
Posted on 03-05-2009 at 11:21:01 AM
you can not preserve transparency in a bitmap image , however the programs which are compatible with bitmap images mostly leave the color "FF00FF" transparent , so if you save this image as bmp and use it then I am pretty sure you will get your desired transparency :yes:
n°11229
xCeres
Posted on 03-06-2009 at 11:46:40 AM
eh, what's the name of the program that I need?
n°11230
truth
Profil: Top Penguin
Posted on 03-06-2009 at 12:10:04 PM
You may use a tool like MyBitmap to do simple things with bitmaps.
Good bye friends.
