23 unknown users
Show "Properties" in My Computer icon in RocketDock?
n°11656
majax79
Posted on 07-14-2009 at 05:18:34 AM
Hello,
I was wondering if anyone knew if it was possible to show properties when right clicking a my computer icon in RocketDock?
n°11657
Posted on 07-14-2009 at 06:51:17 AM
I don't know about it and I don't think rocketdock has any option for including that in the menu.If you use System-Properties that much then you can create a shortcut for it on the dock.Just add a new item to the list and go to its "Icon Settings", in the target field, type 'sysdm.cpl' , choose an appropriate name and icon for it and you are done :)
Message edited by Asher on 07-14-2009 at 04:01:11 PM
Igloo <---> DeviantArt
n°11659
majax79
Posted on 07-14-2009 at 10:20:31 AM
Thanks for the information.
