18 unknown users
How do I create animated pictures from a video clip?
n°11265
xCeres
Posted on 03-16-2009 at 09:54:45 AM
Anyone know how?
n°11267
uttaresh
The Penguin Master
Posted on 03-16-2009 at 11:39:20 AM
Flash can do that. Make a Flash document, put in a video, save it as GIF.
One forum at a time.
n°11268
xCeres
Posted on 03-16-2009 at 12:35:05 PM
So Flash is a program or is it in Photoshop already?
Sorry I'm kinda noob xD
n°11269
uttaresh
The Penguin Master
Posted on 03-16-2009 at 04:04:06 PM
Flash is another separate program, also created by Adobe. It's very expensive, though. Don't buy it just for this.
n°11270
Posted on 03-16-2009 at 04:10:40 PM
Flash is a separate application owned by Adobe, you need to install it separately.
Igloo <---> DeviantArt
n°11271
uttaresh
The Penguin Master
Posted on 03-16-2009 at 05:16:03 PM
Off Topic: Where's you image siggie, kyo? :whistle:
n°11273
Posted on 03-17-2009 at 07:21:04 PM
After the new design of forum , I couldn't make the sig to embed links to it so I removed it ,I'll try to figure it out later ;)
n°11938
heartsoulofra
Posted on 11-07-2009 at 12:30:26 AM
You can use web based gif tools to convert vid to gif - http://www.gifninja.com/ConvertVideoToGif.aspx
- I invite you to join our community dedicated in creating & sharing GIF Animated Pictures
