16 unknown users
CS3 Gradients question/request
n°11013
RDXDukeOfHazard
Posted on 12-29-2008 at 10:59:09 PM
Not sure if this is in the right section (seems to me it is) :wink2: but hey what do I know. :ane:  Anyway I have been trying to get a precise gradients for all the CS3 applications and been having a nightmares making them coz they just don't looks right to me. :oh: :ohill:  I was wondering if anyone has such gradient pack and could share it? If not able to upload anywhere could you guys and girls make some squares using the right gradients with their corresponding names and post them here? Would much appreciate it. :oui:  :cool:  :loveit:
n°11014
Neil
Posted on 12-30-2008 at 03:45:22 AM
Well RDXDukeOfHazard, could you tell us that which type of a Gradient you need to make? Can you tell some details ;)
Any Screenshot may be helpful :smile:
n°11015
Posted on 12-30-2008 at 03:13:51 PM
Yes, some more information is needed. ;) Your question wasn't a tutorial, but a question (duh!). :) So it has to be in the Graphic -> Graphics novice corner (General questions) section of the forum. I'll move the topic there.
Topic moved.
n°11029
RDXDukeOfHazard
Posted on 01-01-2009 at 11:43:29 PM
You know the correct gradients that are being used in making CS3 icons, for example the one for photoshop is blue gradient but I can't get it right myself. :(
n°11032
Posted on 01-02-2009 at 10:24:09 AM
It's probably not one (radial) gradient, but a bit more is added to it as well. :yes: You can download several of these icons online and see how they where made. Also, you can use the Eyedropper Tool to pick colors. :)
n°11034
RDXDukeOfHazard
Posted on 01-03-2009 at 04:37:41 AM
That is correct however, some if not most have the highlight covering the lighter spectrum(s) of the gradient. :frown:
Message edited by RDXDukeOfHazard on 01-03-2009 at 04:38:31 AM
