| rskarun Profil: New Penguin | Hey Guys,
Just wondering how do you put your name/ copyright pictures
so that others cant use it without your permission.
Thanks
Roshan. | |
uttaresh The Penguin Master Profil: Penguin Pro | No way to do that. You can put your name in the meta-data, you can use a watermark, or you can even just write your name in a corner ... but people will still be able to copy it. ---------------
One forum at a time.
y1n14i11 Profil: Penguin | I don´t know how you can save them but you can do it
this picture you don´t can copy in photoshop^^ ---------------
Bad English because German^^
uttaresh The Penguin Master Profil: Penguin Pro | | |
y1n14i11 Profil: Penguin | lol I can edit it also but I don´t can copy it^^ ---------------
uttaresh The Penguin Master Profil: Penguin Pro | What do you mean? If you can edit it ... you can obviously copy it. How do you think I did that?  Message edited by uttaresh on 01-13-2009 at 04:51:08 PM ---------------
Asher Genius is not born , it is made.... Profil: Moderator | You can use even Paint-like simple graphic editor to put name on an image if you want to use it as avatar or signature , however , it depends upon the nature of the picture that another person can change text on it or not - for instance , if you put your name on complete a black area then the text can be made to disappear just by filling the space with black color. ---------------
Igloo <---> DeviantArt
codenamem2k Profil: Big Penguin | Well said Asher...
By the way Utteresh, I like your seal  | |
