18 unknown users
Add animation to a graphic
n°11650
dinkado
Posted on 07-12-2009 at 10:43:10 PM
Hello everyone,
As you can probably guess I am a newbie needing guidance.
I want to add animation to a .jpg I have. It is a picture of a young girl and I have added some gold dust she is holding in her hand. I want the gold dust to twinkle but when I follow the tutorials I have found online for animating the whole picture blinks. How do I get just the gold dust to twinkle and leave the background static? It would be similar to adding the stars to the avatar tutorial.
I hope I have explained what I am trying to do and the problem.
I am thinking that there must be a way to set the background in a frame that does not change.
I have done this in photoshopcs3 and fireworkscs3. I do not have image ready as I see referenced in many places.
Can any one help or point me in the right direction.
Thanks in advance,
dinkado
n°11651
Posted on 07-13-2009 at 05:58:56 AM
Welcome to the community :)
.jpg image files are static images, they can't be animated.You'll have to save the animated file as GIF to preserve the animation.
Can you provide me with the two images (the girl and the dust) so that I or any other member can give it a shot :) ?
Igloo <---> DeviantArt
n°11652
dinkado
Posted on 07-13-2009 at 07:51:07 AM
Thanks Asher!
These are the files I am experimenting with. I am trying to put the blinking star in her hand so it looks like the dust is glittering.
http://www.crystalxp.net/forum/mesimages/334849/glitter1-1.gif2..gif
http://www.crystalxp.net/forum/mesimages/334849/bm2b.gif
Message edited by dinkado on 07-13-2009 at 07:53:18 AM
n°11653
Posted on 07-13-2009 at 04:50:05 PM
Just came up with this:
http://img10.imageshack.us/i/bm2bz.gif/
Just a piece of advice :ar: crop just the part of the image containing the face and the hand, this will reduce the size of the image while keeping the meaning intact :)
n°11654
uttaresh
The Penguin Master
Posted on 07-13-2009 at 04:53:56 PM
Very convincing effect, Asher. :great:
One forum at a time.
n°11655
dinkado
Posted on 07-13-2009 at 10:15:29 PM
Asher thank you! thank you! thank you! That is exactly what I wanted!
One more thing can you tell me how to do it?
with great respect,
dinkado
n°11658
Posted on 07-14-2009 at 06:55:48 AM
Made it in ImageReady .The animation has 4 frames in total, each frame contains same layer of sparkles but with some transformation from preceding one.
