16 unknown users
[Flash Cs4] How to hyperlink images in Flash CS4 Pro
n°11442
thetmyster
Posted on 05-14-2009 at 07:25:56 PM
Hi all :hello:
im doing some work in flash and i wanted to create a http:// hyperlink on an image not a button and it must work in CS4
ive tryed google and most of the tutorials ghive me copmiler error, migration issue function getURL is no longer used :P
and i dont want to have convert the image if possible i like .png  :he:
oh and its in AS3 not AS2 or flash lite :P
Message edited by thetmyster on 05-14-2009 at 07:33:00 PM
http://www.crystalxp.net/forum/mesimages/298907/Sig%20No%20bars%20%20%20copy.png
Glomping the internet populace.http://fc02.deviantart.com/fs48/f/2009/196/0/f/0f93b76ffd0ce94dcd8f1041c69e8b42.gifOne forum at a time.
n°11443
Posted on 05-14-2009 at 07:43:11 PM
You mean on a Graphic File then? :) You'll have to figure out how to do an hit test on an Graphic file in Flash. I'm sure you will find something on Google if you search for hit test. :D
n°11444
uttaresh
The Penguin Master
Posted on 05-14-2009 at 07:59:31 PM
I've used getURL before, and I've also linked images, but I don't remember how; it was a long time ago. :(
n°11445
thetmyster
Posted on 05-14-2009 at 08:03:59 PM
its all so annoying ive now got it as a button and you can click it ..
but it will not take me to a url :P
and apparently in flash CS4 GetUrl Is no longer used (in-compatible :P)
Message edited by thetmyster on 05-14-2009 at 08:08:24 PM
n°11450
truth
Profil: Top Penguin
Posted on 05-15-2009 at 10:22:20 AM
getURL() is out dated now.
AS3 uses flash.net.navigateToURL method which requires
input of type flash.net.URLRequest.
put graphics in a movieclip, instance name like "mc_img1" and..
Code :
  1. import flash.net.URLRequest;
  2. import flash.net.navigateToURL;
  3. import flash.events.MouseEvent; //we'll use all these
  4. stage.addEventListener(MouseEvent.CLICK, evthandler); //let stage listen
  5. function evthandler(evt:MouseEvent):void { //handles all click events
  6.     switch (evt.target.name) {         // name of what was clicked
  7.         case "mc_img1" :          // was movie instance "mc_img1" clicked ?
  8.             var url = new URLRequest("http://www.crystalxp.net/" );
  9.             navigateToURL(url,"blank" );     //open in new browser window
  10.             url = null;     // garbage
  11.             break;           // finished
  12.         default :
  13.             trace(evt.target.name + "no event handler" );
  14.     }
  15. }
Good bye friends.
n°11451
thetmyster
Posted on 05-15-2009 at 12:03:52 PM
wow truth! thanks, ill try that :D
